Author Topic: golf mk2 starter motor wiring  (Read 1135 times)
Offline slee
« on: 01 March 2012, 11:08 »
i have took starter motor off to check it
When refitting it i am not 100 of wiring, checked haynes and it says to just reinstall asa reverse of removal with no pictures
I have wired black wire from battery to top terminal as you look in the engine bay
red spade connector from alternator to connector on starter motor
red wire from alternator to bottom terminal
does this sound correct ?
i am also left with a blue wire which comes from the alternator and has plastic connector on it with snapped brown wire at other end of connector plug but cannot see where this needs to go
any help/advice would be appreciated
cheers
jonathan
