Author Topic: bora 110 tdi re-map?  (Read 4731 times)
Offline NERF 69
« on: 29 February 2012, 16:19 »
Has anyone got a 110tdi bora/golf close to 200bhp? If so what type of modifications would be needed?
Thanks
Sell my Vw??? I'd rather stick wasps up my arse
Offline Rhyso
Re: bora 110 tdi re-map?
« Reply #1 on: 29 February 2012, 16:23 »
Crikey.....
Injectors, turbo, FMIC for starters
Offline Steve_PD
« Reply #2 on: 29 February 2012, 20:57 »
Yep, take the engine out and put in a tdi 150 then remap...... :lipsrsealed:
Offline NERF 69
« Reply #3 on: 29 February 2012, 22:05 »
best be leaving that then. any ideas what i will gain from a good re-map?
Offline Rhyso
« Reply #4 on: 29 February 2012, 22:06 »
About 30bhp  :smiley:
Offline Kus
« Reply #5 on: 01 March 2012, 22:16 »
 :rolleyes: lol
Offline NERF 69
« Reply #6 on: 02 March 2012, 16:48 »
Sorry for the 20 question but im new to having a car that a can modify performance wise but, individually, what gains can i expect from the following:-
Front mount intercooler
stainless exhaust system
induction kit.
Also can i legally run my car(bora 110 tdi 1999) without a cat? Was told it didn't need one but im not sure how true it is
Offline Anthony
« Reply #7 on: 02 March 2012, 18:32 »
yes mate a diesel doesnt require a cat by law , but i did read a post on here from a guy saying it slowed his car down as it lowers back pressure! suppose it depends on what mods you do with it .
2003 GT Tdi 150
Offline EsSeX dAn
« Reply #8 on: 03 March 2012, 08:20 »
front mount intercooler lowers the temperature of aire going into the engine. as cold air contains more oxygen it makes a bigger explosion in the cylinder therefore more power. a lot of people rate a side mount intercooler made by turborevs. its a direct swap for the existing one
induction kit. doesnt do much really as itll just suck in hot air from the engine (heatsoak) so is a bit pointless unless you were to get a dedicated feed one like a pipercross viper, bmc, k&n apollo or one that moves the filter to behind the bumper. carbonio, k&n typhoon.  personally id go fo a pipercross panel filter in the air box and smooth the airbox. use google to find out about that theres loads there
decat. the cat is more of a particle filter on a derv so itll be a bit more smokey. but itll make the turbo spool up quicker and at slight lower revs. the back pressure wont matter on a turbo as it wants to get rid of exhaust gas asap
i think i love you.....
Offline NERF 69
« Reply #9 on: 03 March 2012, 10:10 »
Thanks that's a big help. What would be more effective a front mount or a side mount intercooler?
