Author Topic: ABS Pump error.  (Read 1197 times)
Offline maaarcooose
ABS Pump error.
« on: 29 February 2012, 10:28 »
Hi,
I've just been trying to diagnose the problem with my ABS on my 2001 Polo GTi.
It says that the ABS pump has signal outside specified range.
Does that mean the pump is shot or could it just be a loose connection?
!m!
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: ABS Pump error.
« Reply #1 on: 29 February 2012, 22:10 »
Do you have the actual fault code?
Generally the fault that means its time for a new control unit is "brake pressure sensor failure"   Not to say this fault isnt going to mean the same, but its not a common known fault as such, unless they have renamed it on the polo  :grin:
code will be something like 66-1  if its not a P code.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
