Author Topic: whhhhoooosh  (Read 4517 times)
Offline mkviken
whhhhoooosh
« on: 28 February 2012, 19:33 »
fitted the ITG i bough from sunday driver over the weekend.
car has gained noticeable top end and sounds a bit naughty now. lots of turbo sound and whooshing and fluttering etc
its pretty loud intake, especially at high RPMs but the top end improvement seems worth it.
« Last Edit: 28 February 2012, 20:30 by mkviken »
Golf GTI 7.5 230 white silver
Offline Murrayedition35
Re: whhhhoooosh
« Reply #1 on: 28 February 2012, 19:42 »
It looks good...how long did it take to fit and any problems...
Jimmymature
Re: whhhhoooosh
« Reply #2 on: 28 February 2012, 19:49 »
car has gained noticeable top end and sounds a it naughty now. loots of turbo sound and whooshing and fluttering etc
Have you had your car remapped? I think that intake needs a remap to get the best out of it. Although experts may pop along and advise for a fact.
Jim
Re: whhhhoooosh
« Reply #3 on: 28 February 2012, 19:58 »
No my car is not re mapped....i've been surfing and see you can pick one up for around the 225 mark...
Offline Edi35
Re: whhhhoooosh
« Reply #4 on: 28 February 2012, 20:07 »
Jim
The filter will make the most of the remap and is not worth the expense in isolation unless you just want the wooshing noise  :smiley: Need to add an exhaust too so you can get the gases out  :evil: So you might aswell go for stage 2  :evil: :evil:
Current: GTI Edition 35 Candy White 5dr DSG 19" Glendale, RCD510+DAB, Dynaudio, Storage Pack, Parking Sensors
Gone: Edition 35, GTI Mk6, Edition 30, GTI Mk4, GTI Mk3, GTI Mk2 and my favourite the UR quattro
For those that dont know DSG is an electronically controlled dual-clutch multiple-shaft manual gearbox
Offline mkviken
Re: whhhhoooosh
« Reply #5 on: 28 February 2012, 20:29 »
takes literally 10 minutes to fit. the standard air box is only held on by 4 screws (including 2 for the MAF), 1 bolt and a couple of rubber press studs.
fitted no problem at all. i cleaned and re oiled the filter as i bought it used and though it was clean-ish it was worth cleaning.
Jim
car is stage 1 with milltek cat back so intake should (and feels like it does) give good gains though on a standard engine maybe only a few bhp i don't know.
« Last Edit: 29 February 2012, 18:44 by Snoopy »
Offline RedHP
Re: whhhhoooosh
« Reply #6 on: 29 February 2012, 17:12 »
Jim
Don't forget other mods such as cooling   :smiley:
Red
Mk6 GiT since birth in 2010
YNWA
Offline Snoopy
  • Moderator
  • Geoff.
Re: whhhhoooosh
« Reply #7 on: 29 February 2012, 18:32 »
Nice. You need that on some rollers at some point to see what its now doing.
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline mkviken
Re: whhhhoooosh
« Reply #8 on: 29 February 2012, 18:51 »
think mk5golfgti are doing a day at PDT
Offline Raffe
Re: whhhhoooosh
« Reply #9 on: 24 September 2012, 18:32 »
Sorry to drag up an old thread, but I ave bought Kenny's Carbonio intake and CBE and wanted to check if I can run these for a few months without a remap having been carried out?
Will the car still run ok, or will the filter upset the mixture levels, i appreciate the CBE will clearly have little to no effect.
Any input/ experience appreciated, thanks  :smiley:
