Author Topic: Mk3 VR6 - side mirrors and sunroof not working  (Read 2491 times)
Offline Madone_si
  • Seattle WA, USA and Middlesex, UK
« on: 24 May 2005, 11:58 »
My friend has just brought a MK3 VR6 and the side mirrors are not working at all - what should we look at - to check what the problem is?
Also the sunroof doesn't work properly - it opens upwards fine, but when trying to get it to go backwards into the roof area - it stops after about an 1 inch opening? Is this just were the runners need cleaning or WD40'ing?
Any help would be good?
thanks
Old Skool Mk1 Golf Gli (82), Mk1 US Cab 85 and 83
SOLD - BLACK SOY 92
mrwotto
Re: Mk3 VR6 - side mirrors and sunroof not working
« Reply #1 on: 24 May 2005, 13:17 »
I would look into fuses if both mirrors are not working.
As for the sunroof, open it up and spray wd40 on the runners that you will see and then try opening and shutting it a few times to see if it gets any easier
Offline Madone_si
« Reply #2 on: 24 May 2005, 13:18 »
I'll try that out at weekend - thanks.
SOLD - BLACK SOY 92
mrwotto
« Reply #3 on: 24 May 2005, 13:23 »
No problems, will have a look in my haynes manual when I get home if you want to see what there explanation is, if i dont get back to you by tommorrow pm me and remind me lol
Offline Madone_si
« Reply #4 on: 24 May 2005, 14:58 »
Nice one - thanks alot.
Also oil light has come on today and the oil is not leaking and is showing to Max level - might be relay - can you check that in book too? thanks.
SOLD - BLACK SOY 92
mrwotto
« Reply #5 on: 24 May 2005, 17:51 »
I will have a look but the oil light also indicates low oil pressure
Offline Madone_si
« Reply #6 on: 24 May 2005, 18:09 »
yeah I know that - going to get mate to get that checked tomorrow - that one is a bit serious if it is low pressure.
Had feedback - there was no water in the car - filled up - oil light gone out - advised to put coolant in with water as well - this evening. Wotto do you know the measure of coolant to water? thanks.
« Last Edit: 24 May 2005, 18:28 by Madone »
SOLD - BLACK SOY 92
