The garage
boring old tyre question
Topic: boring old tyre question (Read 1409 times)
Rmachines
Passat 20vT Estate and Candy White MK3 1.8 GL
27 February 2012, 14:27 »
Hi, I have 215/45/17 tyres at the moment, Anyone see an issue with fitting 225/45/17? Its slightly wider, never fitted a wider tyre than standard before. Been given a set of toyo proxies with 6mm on em
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
scarr89
Mk4 Golf, DERV FTW!
Re: boring old tyre question
27 February 2012, 15:32 »
Hmm, the opposite of tyre stretch...Perhaps it will take off
Rmachines
27 February 2012, 17:42 »
you never know
, Its only 10mm diffrence, as long as its safe and physically will fit i will give them a try, cant turn down proxies can i
Wayne
Sir Postalot
27 February 2012, 20:49 »
Should be fine, the rolling radius may be out a little however which might throw the speedo out
Last Edit: 28 February 2012, 10:22 by Wayne
Jaer007ll
Just got here
28 February 2012, 04:54 »
you never know
The garage
