Author Topic: cheap coil spring clamps/compressors  (Read 1966 times)
Offline whit
« on: 26 February 2012, 15:18 »
anyone know where to get a cheap set new?
£10 on ebay am i likely to match that at local motor factors?
thanks
Offline tweed
Re: cheap coil spring clamps/compressors
« Reply #1 on: 26 February 2012, 15:19 »
thanks
What you want them for? You don't need them.
Offline whit
« Reply #2 on: 26 February 2012, 15:34 »
thanks
changing a spring. is it possible without?
Offline kahunajb
« Reply #3 on: 26 February 2012, 16:38 »
It's only £10 how much cheaper do you want them?! :rolleyes:
Don't need them if fitting coilovers as can remove the shock and spring as one but will need them if replacing standard spring.
Mk1 Leon Cupra TDI - Keeping
Mk5 Golf GTI - Revo Stage 1 - FOR SALE £5,250
Mk3 GTI 16v Anniversary - OEM+ - Gone :(
Mk4 GTI 2.0 - Slow - Good Riddance
Offline whit
« Reply #4 on: 26 February 2012, 17:49 »
as cheap as possible LOL :)
standard spring so no way round using them??
Offline murraymint
« Reply #5 on: 26 February 2012, 17:58 »
You can get the spring off without them. As your undoing the top bolt, aim the spring away from you/anything valuable and undo the bolt slowly, and hope it doesn't release to harshly. It's a highly recommended not to this tho might i add. I have done it in the past tho :grin: :rolleyes:
josh
Offline tweed
« Reply #6 on: 26 February 2012, 18:22 »
I undo the nut, change the spring then put my body weight on it to compress then get anyone to quickly put the nut on with couple of turns.
Much faster and cheaper with out the tool
Offline whit
« Reply #7 on: 26 February 2012, 18:34 »
i don't think getting the old one off will be the problem, as the top 2 inches have broken off i assume it wont be under tension???
it's getting a new one on i'm worried about
Offline murraymint
« Reply #8 on: 26 February 2012, 18:38 »
O right, well as tweed said will to it
josh
Offline kahunajb
« Reply #9 on: 26 February 2012, 18:57 »
If the top 2 inches have broken off and not under tension then you won't need the compressors. Should possible to compress manually to reassemble maybe get a mate to help.
