Author Topic: how long does it take for throttle body to re adjust  (Read 2149 times)
Offline stevelfc
how many miles before a mk4 golf 1.8t throttle body re adjust itself after removing and cleaning done about 18 miles and seems when you come to a stop and you press clutch down  it will rev about 1.300 rpm and slowly drop down to normal 800rpm its the AGU engine with cable
Offline s-l-i-x
  • Golf MK4 1.8T AGU
Re: how long does it take for throttle body to re adjust
« Reply #1 on: 25 February 2012, 23:26 »
Not long.
Mine took about 50-80 miles if I remember correctly  :smiley:
Offline stevelfc
« Reply #2 on: 25 February 2012, 23:28 »
cheers m8  :wink: thought it would of settled after a few miles
Offline navmk4gti
« Reply #3 on: 26 February 2012, 11:09 »
Not long.
+1 mine settled after about 40 miles
Offline RnP
  • Audi S4 gone, looking for b5 rs4
« Reply #4 on: 26 February 2012, 14:40 »
as said roughly 40 - 50 miles tends to sort it,
defo worth doing tho,
Offline stevelfc
« Reply #5 on: 27 February 2012, 18:49 »
done 50+ miles now and still the same when i come to a junction and press the clutch pedal down car revs to about 1,300 to 1,500 and slowly drops down to 800 rpm doing my head in now as using more fuel  :angry: wish i never did it now
Offline richw911
« Reply #6 on: 27 February 2012, 19:01 »
Give it a bit longer it will be fine I have done mine loads of times over the years!
Offline tshirt2k
  • Been there...Done that...
« Reply #7 on: 27 February 2012, 19:08 »
Ideally you should do a throttle body adaption via Vag com after any clean. Some cars dont drive very well or at all without it being done.
Mk3 ABF 16VT Megasquirt V3
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #8 on: 27 February 2012, 19:23 »
you tried the door open ignition, on method just to see if that helps?
Leave the drivers door open and turn the ignition on with warning lights illuminated but don't fire it up.
You should hear a buzzing coming from the throttle body, wait until it stops, then turn the ignition off and fire it up as normal. Might work for you, it did for me...
Offline stevelfc
« Reply #9 on: 27 February 2012, 19:29 »
done that m8 but still the same  :sad:
