Golf mk3
hardmonkeys
What size torx bit is required for the gear oil plug?
Topic: What size torx bit is required for the gear oil plug? (Read 1173 times)
twotwofour
GTI forum regular
25 February 2012, 19:47 »
Is it t55? I need to buy one so want to make sure i get the right size.
Its the 020 box. 17mm hex key for the fill/level check plug i believe?
Mk2 small bumper 16v 3dr golf gti
Mk3 5dr 8v golf gti x2
Need a mk1 gti, mk1 caddy, mk3 vr6
VEEDUBMAD123
Re: What size torx bit is required for the gear oil plug?
25 February 2012, 19:53 »
its a 17mm allen key.....rik
Rmachines
Passat 20vT Estate and Candy White MK3 1.8 GL
25 February 2012, 23:38 »
drain and re-fill is 17mm hex, can get them individually or as a set, halfords will do a set for about £15 ish which is always usefull they do the 15/15mm bit for about £5.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
twotwofour
GTI forum regular
26 February 2012, 09:35 »
I'm sure mine is a torx head screw on the drain.
Skred
I like lamp...
26 February 2012, 14:27 »
Or you might get away with just using a wheel bolt head first and grinding the sleeve slightly to accommodate a spanner.
If I'm against picketing, how do I show it?
AudiA8Quattro
Forum addict
26 February 2012, 20:36 »
Buy the proper socket, it's not expensive.
Golf mk3
hardmonkeys
