Author Topic: What size torx bit is required for the gear oil plug?  (Read 1524 times)
Offline twotwofour
« on: 25 February 2012, 19:44 »
« Last Edit: 25 February 2012, 19:46 by twotwofour »
Mk2 small bumper 16v 3dr golf gti
Mk3 5dr 8v golf gti x2
Need a mk1 gti, mk1 caddy, mk3 vr6
Offline Mitching
Re: What size torx bit is required for the gear oil plug?
« Reply #1 on: 25 February 2012, 20:56 »
It shouldn't take a torx, IIRC you'll need a 17mm allen key.
Or a wheel bolt fits in there so if you have a spare one and a welder, weld a nut on the thread and that should do!
Offline Reasty
  • Alpine white valver.
« Reply #2 on: 26 February 2012, 08:25 »
Yep it's a 17mm Allen bolt ,probably the only one you won't have in your tool kit  :grin:
« Last Edit: 27 February 2012, 08:46 by Reasty »
Offline Mitching
« Reply #3 on: 26 February 2012, 10:06 »
I ended up buying a drain plug key from halfords, it's designed to fit on a ratchet and was only about £2.50
Offline AudiA8Quattro
« Reply #4 on: 26 February 2012, 20:37 »
This.
