Author Topic: quick answer needed  (Read 1084 times)
Offline Gash
quick answer needed
« on: 25 February 2012, 15:20 »
right in the middle of changing my fuel filter over.
the old one looks the same as this...
yet the new one has the arrow pointing the other way. the big lip at the bottom has the arrow pointing away in the photo, on my new one it has it pointed towards.
dont want to change it and it be wrong mounted or anything so any help quickly be great.
Offline Screech16v
  • MK3 20vt AGU
Re: quick answer needed
« Reply #1 on: 25 February 2012, 15:36 »
Just install with the arrow pointing the same way as your old filter(direction of flow)  :smiley:
Offline Seanl
« Reply #2 on: 25 February 2012, 15:52 »
Uh, I'd install it as its labelled on the new one, not how it is on the old one. its only a sealing join, could be any way whichever way each and every manufacturer decided to put it.
Offline Screech16v
  • MK3 20vt AGU
« Reply #3 on: 25 February 2012, 16:09 »
That is what i said  :rolleyes: Arrow same way as old one,never said anything about the filter body  :laugh:
VW BUSH
« Reply #4 on: 25 February 2012, 17:55 »
Mount it at 90 degrees to the arrow if you are unsure :wink:
Offline VEEDUBMAD123
« Reply #5 on: 25 February 2012, 19:15 »
its ok fell just put the arrow the same way and it will be all good mine was the same nothing wrong just made that way.....thanks Rik
