Author Topic: pinking issue  (Read 2332 times)
Offline Simpson
  • one day il learn
pinking issue
« on: 25 February 2012, 12:39 »
Well traced my timing issue down to there being 3 bolts missing from the left side of the inlet manifold and the others had come lose, no wonder it has run crap for weeks. Replaced those and the engine still pinks under load at slow pace. The timing was checked before the bolts were found missing.
Would the timing need to be done again now they are replaced. Blue sensor seems to advance like it should alos.  Thanks
i must buy a new car!
Offline rossbarry1
Re: pinking issue
« Reply #1 on: 25 February 2012, 14:31 »
what car?
Offline Simpson
  • one day il learn
Re: pinking issue
« Reply #2 on: 26 February 2012, 04:13 »
sorry mk gti 8v digi
Offline rossbarry1
Re: pinking issue
« Reply #3 on: 26 February 2012, 11:33 »
recheck ignition timing. follow rubjohnnys guide. worked for me.
Offline danny_p
Re: pinking issue
« Reply #4 on: 26 February 2012, 12:12 »
check the knock sensor or just replace it
all the VW's have gone bar 1.
Offline Simpson
  • one day il learn
Re: pinking issue
« Reply #5 on: 26 February 2012, 18:20 »
cheers will do  :smiley:
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: pinking issue
« Reply #6 on: 26 February 2012, 19:22 »
Is that actually a genuine sensor? A knock sensor? What the F does it measure, if something is banging against it? Also what is pinking?  :undecided:
Offline dan2252
Re: pinking issue
« Reply #7 on: 27 February 2012, 20:05 »
knock sensor basicaly.. sensors for a knock from the engine, and if it detects a knock it puts the timming back,
MK4 golf 1.8 turbo agu :)
Offline danny_p
Re: pinking issue
« Reply #8 on: 27 February 2012, 22:54 »
pinking is also know as spark knock,   knock sensor measures knock or pinking
to be more technical they are a peizo electric microphone that is tuned to sensitive to vibrations in the block at around 5.5 khz   ( the frequency of the sound you hear thats called pinking )
Offline Kamshaft
Re: pinking issue
« Reply #9 on: 02 March 2012, 00:03 »
Pinking is detonation, which means that fuel is spontaneously igniting in the chamber.
Normally the air fuel mixture should ignite at the spark from the plug and the flame should spread evenly through the chamber.  When you are getting pinking it's because the fuel is igniting at the edges of the chamber  before the flamehas spread to that part of the chamber.  Its normally caused by hot spots in the chamber. Detonation occurs after the spark and engines can handle a certain amount of detonation.  It is normally sensed by the knock sensor and the ECU will retard the ignition timing to eliminate it.
It is often confused with pre ignition which is when the fuel ignites in the chamber before the spark and is much more damaging to engines, normally even one incident of pre ignition will mean costly engine repairs.
