Author Topic: Plastic arch liners  (Read 912 times)
Offline johnomk4
Plastic arch liners
« on: 24 February 2012, 22:06 »
As above, is anybody running with out them, or had to cut them because of rubbing?
Offline symsymma
  • AGU POWER,drive it like u stole it!!!
Re: Plastic arch liners
« Reply #1 on: 24 February 2012, 22:16 »
Would have thought it would be a bad idea to remove them completly water and crud would go every where.ive heated them up on other cars ive had and remoulded them using a heat gun to stop rubbing issues.
1.8T AGU 203bhp & 233lb/ft Rtech stage 1 custom remap,18"dezentz rims,lowered 40mm shocks n springs,whiteline 24mm adj rear arb,lcr axle bushes,polybushed arb,modified front bumper & valences,depo projector headlights,delocked,wrapped interior&bora gear knob,forge boost & coolant hoses,forge tip,forge 007p,samco vac hoses,simota aeroform cai,saiko michi catch can,deleted pcv system,r32 dogbone,miltek lg bore down pipe & sports cat/non res anni style system.
Offline johnomk4
« Reply #2 on: 24 February 2012, 22:24 »
That's just it, I don't want to remove them because of all the crap that will go up there, but haven't got a heat gun, will uve to get one.
Did you have any probs with paint peel after tho?
Offline cullygti
« Reply #3 on: 24 February 2012, 22:27 »
how low are you to cause rubbing as im down all the way on my coilies and no probs at all
Offline Chris#101
« Reply #4 on: 24 February 2012, 22:30 »
does anyone know off hand a ball point mark for these from the stealers!? my front two are starting to look at bit worse for wear  :lipsrsealed:
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline symsymma
« Reply #5 on: 24 February 2012, 22:34 »
ive only ever heated the inner edges and backs if you like of the plastic liners to stop rubbing on inside edges of tyres, dont heat up anything near your paint work for god sake!
Offline symsymma
« Reply #6 on: 24 February 2012, 22:36 »
hazard a guess £25 each side  :undecided:
Offline johnomk4
« Reply #7 on: 24 February 2012, 23:16 »
Will have to measure it tomorrow. It's on the outter edges I'm having the problems, and it's not even all the way down on the front yet. The backs only rub on hard cornering.  :sad:
I won't be heating by any paint that's for sure. Lol
