Author Topic: bolt questions  (Read 659 times)
Offline mk3tony
bolt questions
« on: 24 February 2012, 11:40 »
I've got some ch reps, 8.5j et35. is it the normal case of tapered bolts needed? they came with longer bolts, is there any danger of using longer bolts? i'm going to order some 20mm spacers for the rear so they will come with the necessary bolts but i'm worried as they are llonger than standard bolts by nearly 10mm
2001 1.8T AUM - Rtech Spec 1 Custom Map, Catch Can, Cone Filter, 209bhp 237 lb/ft, SuperPro Wishbone and Rear Beam Bushes, Jom Coilovers, 19" BBS CH Reps
Offline Toby
  • Car - less
Re: bolt questions
« Reply #1 on: 24 February 2012, 11:43 »
Use standerd size bolts if you have no spacers.
Currently down under
Re: bolt questions
« Reply #2 on: 24 February 2012, 14:04 »
With no spacers you need standard bolts as longer bolts could catch where they pass through the hub.
