Author Topic: Struggling to go  (Read 3797 times)
Offline DMcK
  • Red MK4 Golf 1.8T. Unmolested...Soon to change!
Re: Struggling to go
« Reply #10 on: 23 February 2012, 23:33 »
Right i'm going to order it now. Where does it plug into by the way?
Offline navmk4gti
« Reply #11 on: 23 February 2012, 23:34 »
If you have a laptop to hand then just get the cable because you can copy and save the fault codes and givea u short description what it is etc.. The code reader is more for on the go and will only show you the code.
Offline barrym381
« Reply #12 on: 23 February 2012, 23:34 »
above your ashtray a small bit of trim comes off an plugs behind that
Offline barrym381
« Reply #13 on: 23 February 2012, 23:35 »
they come with a book that tells u the fault
Offline bobbieboy69er
  • MK4 1.8T AUM
« Reply #14 on: 23 February 2012, 23:35 »
Cheers Barrym and navmk4. What you guys think would be better, just the lead or one with the reader to. I don't mind spending up to 25 quid. And yeah navmk4 the link come up mate.
What version of windows you running?  VAGCOM is the best choice as you can log aswel  :cool:
MK4 1.8T AUM|30mm Eibach Springs|Milltek cat back|4mo rear valance|pipercross filter|R-tech Stage 1 Remap|Baileys DV|Powerflex Front and Rear Bushes|312mm Front Brakes|Creation Motorsport TIP and hoses|17" TT Ronals|  220BHP
Offline DMcK
« Reply #15 on: 23 February 2012, 23:40 »
Ooops i've ordered the handheld one. I will order the lead to then. For when i'm not on the go, least i will have both then  :laugh: And im running windows 7 mate.
Offline navmk4gti
« Reply #16 on: 23 February 2012, 23:41 »
You dont need both.
  • MK4 1.8T AUM
« Reply #17 on: 23 February 2012, 23:42 »
VAGCOM is better but dont fink it works on Windows 7.... only Vista and XP (unless you pay for it from VAGCOM)
Offline navmk4gti
« Reply #18 on: 23 February 2012, 23:45 »
Does work on windows 7. Look at my how to on vagcom section that will help  :wink:
Offline daz veedub
  • Operation 1.8t bolf
« Reply #19 on: 23 February 2012, 23:47 »
just buy the handheld 1 it comes with a booklet with codes in etc and u can search here and rosstech for more code info
