Author Topic: mayo on oil cap filler  (Read 1537 times)
Offline forsh
« on: 23 February 2012, 17:14 »
not run my vr for 5 days and did a little check today ,check oil cap and oil dipstick,needed about 1 liter oil,did oil change about 3 months ago
there was a little mayo on the oil cap filler
ive not run my car for 5 days and when i do run it i only drive 35 km per day monday to friday
coolant is ok,doesnt get above 90oc
oil very rare goes above 95oc on hot days
it winter here in finland and its been minus 10 and minus 20 some days
last few days its been only minus 5 max and today when i check the car its plus 1 plus 2oc
is it the gasket or is it i only run small journey etc
the coolant in the expansion tank looks clean
Offline clancy
Re: mayo on oil cap filler
« Reply #1 on: 23 February 2012, 17:17 »
Could well just be like moisture build up, pretty common. Not sure how you would tell if it is just general build up or the head gasket though
MK3 GTI 16v
Offline Luke1981
« Reply #2 on: 23 February 2012, 17:40 »
1 litre of oil lost in 3 months would suggest something is wrong mate  :sad:
It's must be leaking somewhere! Get the head checked asap and work from there
MK IV GT TDI 150 PD / MKII CADDY SDI
Offline Milby
« Reply #3 on: 24 February 2012, 15:34 »
mine had a bit of mayo in cap just took it for a good blast and its gone  :smiley: but losing that much oil doesn't sound healthy  :undecided:
MK3 Golf 1.4 SE ;)
Offline forsh
« Reply #4 on: 25 February 2012, 14:57 »
the oil was clean so i thought it was about a liter,it was less then half a liter,i put a liter in and it was well above the top line on the dipstick
took it for a dirty run and mayo dissapeared,
took it to work and my friend had that carbon test tik spare,it was clean
im happy that its ok and thanks for all imput you guys
Offline VEEDUBMAD123
« Reply #5 on: 25 February 2012, 19:21 »
don't worry to much mate its the condensation the engine produces on warm up it mixes with the oil but not a problem just clean your breather system and should be ok for a while mine does it .....thanks Rik
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #6 on: 26 February 2012, 00:01 »
1L in 3 months is a lot, but the hondas i work on, as a new engine they are allowed to burn up to 1L per 600miles before it requires work done on it,  allthough they dont burn that much, if you think that is the allowable limmit, yours is likely well below that (i know honda/vw is very diffrent) but the point is, your proabably fine,  cold engines burn more due to components being loose which doesnt help,  a bit of mayo is also normal after short trips, clean it up, take her for a damn good thrashing, if it returns during a hot run worry, if its gone, all should be fine.  :smiley:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
jedimasterlewis666
« Reply #7 on: 27 February 2012, 15:21 »
1lt every 3 months does not seem too high for a vr which use quite a lot to be honest.
you will get mayo on short runs for sure. let your car warm up each morning before driving and give it a foot full should stop the condensation building inside the cap
