Author Topic: Rough running! - update further help??  (Read 3836 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Rough running! - update further help??
« Reply #10 on: 25 February 2012, 14:24 »
what engine code
you need to check all the PCV pipes in the engine bay for leaks including those under the inlet mani
Offline bigmarky
« Reply #11 on: 25 February 2012, 14:30 »
It's AGU mate
Tornado Red, 99 AGU, full milltek, K & N, forge007p, 18\" A8 in custom Matt Black with Anthracite inserts, Custom remap, 22psi boost, HID\'s, full led\'s, bodykit.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #12 on: 25 February 2012, 14:37 »
hate to say it but ignition amp?
Offline bigmarky
« Reply #13 on: 25 February 2012, 14:59 »
It just seems to happen as the boost maxes out though I mean when u floor it the boost is now hitting about 35psi (I'm assuming this is way too high) its then juddering misfiring then keeps going it doesn't do it all the time or under normal acceleration.
Offline richw911
« Reply #14 on: 25 February 2012, 19:58 »
Any fault codes? faulty N75....
Offline bigmarky
« Reply #15 on: 25 February 2012, 20:00 »
Getting it plugged into vag.com tomorrow mate so hoping that will come up with something
Offline tokemk4gti.t
  • 2001 gti turbo :-)
« Reply #16 on: 25 February 2012, 20:10 »
whats it sound like??? 35psi!!!! mines 18psi and it spools hard!! 35psi man id be scared hearin that spool :-s
Offline bigmarky
« Reply #17 on: 25 February 2012, 21:27 »
It sounds like a supercharger mate way too loud trust me, it's quick but just waiting to go bang!!!
Offline jonnyturbo
« Reply #18 on: 26 February 2012, 16:32 »
Well I scanned marks car today and the codes are as follows
16487 - Mass Air Flow (MAF) (G70): Signal too High
16516 - Oxygen (Lambda) Sensor B1 S1: Signal too Low
Would these two cause erratic over boost ? Was no overboost codes . The above was all that was there bar a daft immboliser fault
Offline bigmarky
« Reply #19 on: 27 February 2012, 18:35 »
Changed MAF today, left battery disconnected to reset, tried and problem still there, boosting to over 35 psi !!!! Any ideas ???
