Author Topic: White smoke?  (Read 3782 times)
Offline Mattb87
White smoke?
« on: 22 February 2012, 23:20 »
Am I right to think White smoke is a sign of unburnt fuel on a petrol vehicle
Offline dan2252
Re: White smoke?
« Reply #1 on: 22 February 2012, 23:46 »
tends to be black unburnt fuel. if i remember white is normaly water? correct me if im wrong but im pretty sure mate, its not just steam is it?
MK4 golf 1.8 turbo agu :)
Re: White smoke?
« Reply #2 on: 22 February 2012, 23:49 »
White smoke is a sign that water is entering the combustion chamber so could a sign your head gasket is in trouble.
Offline ScottA
Re: White smoke?
« Reply #3 on: 23 February 2012, 00:26 »
Or it could just be moisture in the exhaust etc
Offline Mattb87
Re: White smoke?
« Reply #4 on: 23 February 2012, 02:01 »
Well been having running problems so basically cat has been replaced today, no water loss atal from header tank was thinking maybe lambda sensor problem
Offline Mattb87
Re: White smoke?
« Reply #5 on: 23 February 2012, 02:05 »
But also haven't had the car on the road for about 3 weeks now
Re: White smoke?
« Reply #6 on: 23 February 2012, 13:45 »
Mixture / fuel problem would be black smoke.
Offline AlexMozza
Re: White smoke?
« Reply #7 on: 23 February 2012, 20:06 »
Sounds like water in the chamber. How long have you run it for, if it was condensation, after a 20 mile drive you would expect it all to boil off.
I would take it for a fair distance drive, if it clears up then it was moister, if not sounds like HG trouble.
Wip the head off, get it skimmed and then put a new HG on :D
2001 Satria GTi
Mini 25 Special Edition 1984 998 :D
Formula 3 Mechanic
Offline Mattb87
Re: White smoke?
« Reply #8 on: 23 February 2012, 23:10 »
Must of been condensation as seems to have cleared up now, may get emissions checked anyway
Offline gedbedhead
Re: White smoke?
« Reply #9 on: 28 April 2012, 21:17 »
its also wise to check your brake fluid level have heard of instances of fluid leaking past the servo into the vac,when burnt off white smoke.
