Author Topic: Mk2 20vt fuelling  (Read 1489 times)
Offline Chris_mk4_golf
Mk2 20vt fuelling
« on: 22 February 2012, 23:00 »
Hi guys hope you can help
Im currently going through a mk2 20vt conversion and have stumbled into a somewhat confusing area im not familiar with
I dont know what kind of set up to go with for fuelling
Im going to be running a KO4-022 with badger5 TIP (v1), baileys DV, FMIC, 3" MAF so far
Ive no idea what kind of pump to go for
3bar/bar regulator?
what injector size should i go for?
What set ups have you gone for with what power results?
Many thanks
Re: Mk2 20vt fuelling
« Reply #1 on: 23 February 2012, 00:23 »
Bump?
Offline danny_p
« Reply #2 on: 23 February 2012, 23:07 »
what power output are you going for ?    from that you can aproximte your fuel requirements to size your injectors
run ether a 3 or 4 bar reg just size the injectors accordingly
id use ether a bosch 044 or a walbro 255   uprated  pump to allo for more in the futcher
but a mk2 16v kjet pump will be ok on a 4 bar FPR with   injectors from a 225 engine  iirc 380 ish  cc/m   if buying them new would prob go for 400 or 450's
all the VW's have gone bar 1.
