Author Topic: Couple hrs at garage.. the findings!  (Read 1077 times)
Offline kennedyuk2001
« on: 22 February 2012, 13:03 »
Ok have ABS problems and this dam limp mode so spent the morning at my good friends garage.
Have checked and cleaned and cleared the ABS light codes, All seems ok but still bring up ABS light. Gonna try replcing the sensor, we phoned for a price £55 quidish.... that can wait I decided.
Gonna look for a 2nd number.
Onto the turbo, actuator looks free, we got vac pump on there and seems to move freely. Checked the condition of all hoses and look ok. Plus no signs of any leaking air from them either.
Hooked up to his fault reader and gave a new code:-
17964 - P1556 Turbo super charger boost sensor (A) circuit : control limit not reached.
Now, is this the infamous N75 on the bulkhead causing this? and will this be the limp mode cause?
Offline Toby
  • Car - less
Re: Couple hrs at garage.. the findings!
« Reply #1 on: 22 February 2012, 13:36 »
Check the erth fuze for the abs light! I had the same!
Currently down under
« Reply #2 on: 22 February 2012, 14:01 »
Where will I find that?
« Reply #3 on: 22 February 2012, 15:38 »
Also its not on all the time, comes and goes, so what that rule out a fuse?
Offline Toby
  • Car - less
« Reply #4 on: 22 February 2012, 18:08 »
On the battery.
Offline Scott D
« Reply #5 on: 23 February 2012, 00:22 »
think that is the MAP sensor rather than N75
faulty MAP sensor will cause limp mode if playing up.
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
« Reply #6 on: 23 February 2012, 08:01 »
Mmm never knew map, could cause limp mode.
