Author Topic: sump plug size???  (Read 5093 times)
Offline Tomonator1985
  • Low 'n' Slow
sump plug size???
« on: 22 February 2012, 08:54 »
trying to do an oil change....no sockets big enough.......what size is the sump plug on a mk2?
19mm? 24mm!?
help!
need to buy new tools and don't want to come home with the wrong set!!!
thanks.
*MK2 Golf GTI 16v Small Bumper*
Offline rob.043
Re: sump plug size???
« Reply #1 on: 22 February 2012, 08:57 »
19mm? 24mm!?
help!
thanks.
pretty sure its 17 or 19. Leaning towards 19
Offline Simpson
  • one day il learn
« Reply #2 on: 22 February 2012, 09:03 »
19
i must buy a new car!
  • Low 'n' Slow
« Reply #3 on: 22 February 2012, 09:09 »
all I know is that is is big. I'll jsut get the largest sockets i can afford i guess.
Thanks.
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #4 on: 22 February 2012, 09:32 »
Don't forget to use a new copper washer.
  • Low 'n' Slow
« Reply #5 on: 22 February 2012, 09:50 »
do i need a new wassher if im just letting oil out?
over filled it like an idiot....
« Reply #6 on: 22 February 2012, 09:57 »
Ideally.  It's a soft copper washer which is squashed on tightening to provide a seal.
Obviously once used, it's not as effective the second time around.
Offline Sam
  • Sam I am
« Reply #7 on: 22 February 2012, 10:09 »
New washer should come with a new sump bolt, which you should have, which should be magnetic too  :smiley:
  • Low 'n' Slow
« Reply #8 on: 22 February 2012, 11:03 »
....yeah i'm out of my depth.
Basically ive got to drive it to margate from sittingbourne (kent) for some work and i've overfilled the oil like a *beeeep* and need to let some out before i drive it....
...ideas?
Offline Sam
  • Sam I am
« Reply #9 on: 22 February 2012, 11:59 »
...ideas?
No pun intended I assume, your only option is the sump plug, just loosen it and drain a little out. Dont fully remove it cos you wont get it back in without fully emptying your engine of oil.
