Author Topic: FPR Pipes  (Read 3042 times)
Offline tokemk4gti.t
  • 2001 gti turbo :-)
FPR Pipes
« on: 20 February 2012, 21:50 »
right the kind of nylon coated pipes all around the FPR where the boost gauge lives and all around that side of the inlet manifold are a flaking brittle mess as i found out when i fitted my gauge the other day :-/ what size are the tubes and is ot gonna cause much of an issue if i leave it for a while?? my gauge shows 16 psi and drops back to 12  :shocked: can those tubes cause boost leakes or not?
Offline cullygti
Re: FPR Pipes
« Reply #1 on: 20 February 2012, 21:52 »
should have been done with the guage they are easy to do and 4mm iirc  :wink:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: FPR Pipes
« Reply #2 on: 20 February 2012, 21:53 »
yup they will affect boost and general running if they leak
Re: FPR Pipes
« Reply #3 on: 20 February 2012, 21:59 »
leak??? the friggin holey lol all of them every pipe in that area is ruined!!!! wheres best to get them pipes?? i have got some spare stuff in my van but thats air pressure switch tubing for boilers  :smug: might be a bit soft silicone
Offline cullygti
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: FPR Pipes
« Reply #5 on: 20 February 2012, 22:47 »
yep or rubber pipe mate. choice is yours :wink:
Re: FPR Pipes
« Reply #6 on: 20 February 2012, 22:50 »
cheers boys..will zip ties be ok with that pipe??
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: FPR Pipes
« Reply #7 on: 20 February 2012, 23:06 »
they're holding mine on :afro:
Offline big stevie
  • "what doesnt kill me makes me stronger"
Re: FPR Pipes
« Reply #8 on: 21 February 2012, 16:39 »
hmmm just fitted boost gauge to mine and my pipes are quite perished, i have some 4mm silicone pipe left over will it be ok with the heat i thought that pipe was covered in that material to protect from the heat, but if silicone will be fine i will change my perished pipes for the silicone.  :smiley: :smiley: :smiley:
black 5 door 18t aum engine with 19" lm reps and homemade induction, awesome forge 007p,pressed plates, pillar mounted boost and voltage gauge.
Re: FPR Pipes
« Reply #9 on: 21 February 2012, 16:46 »
ive just ordered some of flea bay dude shoul be ok now i no how bad they get i will keep an eye on them.. and i think i may jave the same pod as you lol was that off dubber t or summat on ebay? loo i might drop the pics on later
