Author Topic: HELP! Rough running driving me nuts!  (Read 984 times)
Offline loz7oz
« on: 20 February 2012, 17:00 »
I have some rough running problems with my ADY engine on my mk3 golf.
The mechanic has replaced most things and is now saying it's probably to do with the vacuum hose setup. Not sure what this means as i'm a girl  :rolleyes:
Can anyone shed any further light on the attached photo. If you look at the vacuum hose from the throttle body to break servo, next to valve you can see it has a screw in one pipe the other left open. This doesn't seem right and when I fiddled with them it almost cuts out!
So if anyone can compare this with theirs i'd be grateful.
Uploaded with ImageShack.us
Offline trog_nfs
Re: HELP! Rough running driving me nuts!
« Reply #1 on: 20 February 2012, 17:35 »
From the factory they have bungs in them. The usually break and fall off at some point.
I think on your model they both need to be blanked off. The symptoms you are describing are classic vacuum issues.
On mine, the far right one is blocked off, and the left one is in use, but I think thats because I have air con
Offline thebassman
« Reply #2 on: 20 February 2012, 17:42 »
I alo have an ADY engine, both of mine are capped off with little green plastic caps. Seems to run pretty smooth.
Thebassman
Offline loz7oz
« Reply #3 on: 21 February 2012, 08:46 »
Thanks guys really appreciate your help  :wink:, I will block both of them off and give it a go. Fingers crossed!
Offline mrsaunders
« Reply #4 on: 21 February 2012, 17:56 »
dont worry i have the same problem on my ady aswell,
http://www.golfgtiforum.co.uk/index.php?topic=222770.0
looks like there ment to be blocked off, yet another job to do
