Author Topic: Mk2 gti 8v running rough and slightly under powered  (Read 8397 times)
Offline busterdub
« on: 20 February 2012, 15:57 »
Hi all
My 8v is running and sounds like its a john dear tractor, it idles fine, but it's very lump under acceleration and seem to have lost power, sometimes just for a brief second it goes like it should, is something loose? I thought it was the throttle body gasket as heard a slighty sucking noise when setting off plus I changed the body as the switches were goosed! Even check the plugs... Any pointers?
Offline walchy01
Re: Mk2 gti 8v running rough and slightly under powered
« Reply #1 on: 20 February 2012, 16:44 »
Had this sort of thing with mine, check your leads as one had mine had broken in 2 places within the rubber on my valver, also check your coil, as again had sparks coming from mine which also resulted in a jumpy ride as and when it felt like it, when you put the foot down it holds back and is hesitant.. Check all air pipes are connected from  the air box etc also :wink:
Offline apie2004
« Reply #2 on: 21 February 2012, 09:28 »
Cracked exhaust manifold?
Offline busterdub
« Reply #3 on: 21 February 2012, 10:26 »
May be? The exhaust note has changed, and has become very 'poppy' at the outlet.....
Offline apie2004
« Reply #4 on: 21 February 2012, 12:25 »
Have a feel around the back of the engine, dont touch the downpipe/manifold but if it is cracked you should be able to feel the exhaust gases escaping.
Offline mk2bal
« Reply #5 on: 21 February 2012, 13:52 »
If its a digi 8v it might benefit from a new blue coolant sensor and a tune up as per rj's guide.. Can be quite critical to the running of the digi's. A mates 8v banged popped and had no power until a good sort out
Offline busterdub
« Reply #6 on: 21 February 2012, 18:37 »
We're can I find this guide?
Check the manifold and it's not blowing?
Offline busterdub
« Reply #7 on: 21 February 2012, 22:36 »
Yeah thanks I had a nosey before, it was the rj that threw me didn't know it ment rubjonny But cheers for the link
http://www.golfgtiforum.co.uk/index.php?board=40.0
Offline Simpson
  • one day il learn
« Reply #8 on: 22 February 2012, 08:50 »
check very carefully the rubber intake hose for cracks, also mine has a similar problem traced mine tobe the inlet manifold gasket causing her to run lean. On mine i kept trying to seal the intake hose aS when i slightly held it at the back the squeeling stopped! This is due to the weight on the seal by putting weight on the inlet manifold,
Currently remedied by some tight rope till i can be bothered to change it!   :grin:
i must buy a new car!
Offline busterdub
« Reply #9 on: 22 February 2012, 09:41 »
Just tried the inlet manifold it isn't that as its solid and made no difference..... But I did noticed a clear liquid on manifold near the injectors and the exhaust flumes smells of fuel
