Author Topic: which turbo  (Read 2844 times)
Offline kennedyuk2001
which turbo
« on: 20 February 2012, 09:21 »
Which model of turbo does my AJM have, and is it possible to fit bigger in it, what would it need doing on top if i got bigger turbo.
Offline NoCrap
Re: which turbo
« Reply #1 on: 20 February 2012, 21:00 »
a lot - injectors, air intake ducting, other cooling components... the AJM is also renound for having head gasket issues so i wouldn't be supprised if you'd be changin that within a few K miles
Re: which turbo
« Reply #2 on: 20 February 2012, 21:03 »
Head gaskets eh, never a problem one wants.
Do you know what the turbo it has fitted just now? I may need to replace if I cant get it running better and throwing limp mode.
Still got loads to do before I would change it but would like to know for future ref.
Offline NoCrap
Re: which turbo
« Reply #3 on: 20 February 2012, 21:51 »
indeed - will be fine on a standard setup but with a few more ponies going through i reckon it'd pop easily.
i dont know what ones fitted as standard - should have looked when i had mine off but forgot.
it's easy enough to take off and check the veins, etc - have you checked the n75 valve and vacuum pipes?
Re: which turbo
« Reply #4 on: 20 February 2012, 22:13 »
not yet on the to do, just need some decent weather.
