Author Topic: Wheel Alignment  (Read 1543 times)
Offline ryanbrook
Wheel Alignment
« on: 19 February 2012, 22:56 »
Can the rear wheels be aligned on a VW Golf MK3 1.4
Re: Wheel Alignment
« Reply #1 on: 19 February 2012, 23:36 »
Nope, if they are out you have a problem.
Offline mk3.owner
Re: Wheel Alignment
« Reply #2 on: 20 February 2012, 03:20 »
Unless you tightened you'r wheel's up on the wonk.. If not..
Case Closed
Offline boneybradley
  • Back in a Mk3...
Re: Wheel Alignment
« Reply #3 on: 20 February 2012, 11:07 »
Can I ask why you need the rear wheels alinging? (it's a solid axle and unless it's bent they should be in the correct position)
b.t.w all mk3's have rear wheels that sit in the rear aches different! (one side normally sits 5-10mm more outward due to vw's early 90's quality control  :grin:)
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Wheel Alignment
« Reply #4 on: 20 February 2012, 14:32 »
Can the axle be shifted on its mounts centrally then? I can't remember seeing any tolerance when I've done rear bushes.
  • Back in a Mk3...
Re: Wheel Alignment
« Reply #5 on: 20 February 2012, 17:20 »
If the mounts are fine the axle has to be central, worn bushes and it could be all over!
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: Wheel Alignment
« Reply #6 on: 20 February 2012, 19:38 »
The rear axle mounts can be moved where they bolt to the chasis, they say to remove the rear beam using the bush bolts to avoid miss aligning it, so yes there is a certain amount of alignment in the rear beam, but its not tracking as such.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
