I'm thinking of buying a W reg 2000 Golf 1.8T that has the ARZ engine in it. The bloke has been honest about it, says that its had an engine swap at some point to an ARZ and is fly by wire throttle. He says it has a straight through exhaust, decatted with the lambda sensors removed???
He says that in the mornings it takes ages of cranking to start, then runs lumpy for about 30 seconds then is perfect after that. His mate then said that if you turn the ignition on/off to "prime the injectors" it fires up a lot better. Once its warm it starts fine.
The car is cheap for what it is, and he's been honest about the issues but I just want to know if i'm in for a can of worms or a simple(ish) fix.
Its a 300 mile round trip to view the car so i'm obviously trying to get as much info as poss to save a wasted journey.
I know people will tell me to walk away, but with a limited budget I have to get a car thats likely to have some issues that I can then work on and improve/repair.
Any help/advice is appreciated. Thanks
