Author Topic: Any Nice MK1 Enthusiasts willing to help a female in need????  (Read 6957 times)
Offline Redbaron
 :rolleyes:
No problem, anytime!
a nice mk1 by the way, but just a note, noticed some rust coming through on the inner wings (when/if you open the bonnet, follow the line of the wing up towards the windscreen, there is a cavity below the screen - the outer walls of that) and also i had a quick peek at the sills which also have some surface patches which if caught now-ish will be ok.
Quite refreshing to see a young professional female with some taste in cars!
If you need it servicing or anything dont hesitate to ask!
Oh and a gear-linkage bush kit from GSF in Farnham is about £15 which will sort out your soggy box (oooh errr missus  :wink:
Just to clarify - was the fuse for the fuel pump relay (later spec relay?)
 :grin :cool:
Offline Victorialou
I had noticed that the gearbox was a bit sloppy, but put it down to the fact I had been driving a delightful* 1.2 Punto rental car for a while with smooth everything prior to buying the golf.
If a gear linkage kit is only 15pounds then having that changed could be your next task, if you like.  :laugh:
I am not sure what to do about the rust, bearing in mind that I anticipate heading back to the states in about 3 months and will be selling it.  Have to have a ponder on that one.
I believe it has been serviced recently, but I will check the oil condition and have that done in addition to the gear linkage change.
Oh, I dont think I can, its a two person job to open that bonnet, remember?  :huh:
Cheers again for your help Alex, let me know your availability.
*(sarcasm)
Offline Len
Only gonna be around for 3 months!
Oh well.
Welcome to the madhouse anyway!
www.sas.org.uk
www.the-ace.org.uk
