Author Topic: 1.6 Golf Ryder Mods  (Read 1602 times)
Offline capoot
  • Mk1 Skoda Octavia VRS
1.6 Golf Ryder Mods
« on: 22 May 2005, 17:57 »
What mods can i add, filter, exhaust etc?
Re: 1.6 Golf Ryder Mods
« Reply #1 on: 31 May 2005, 10:21 »
Forget modding or replacing the airbox, no point and will end up giving you more greif in the long run with carb icing and power loss due to it sucking in only warm air from the engine bay.  At most fit a K&N pannel filter to replace the stock filter :)
If you want REAL benefits, fit a full MK2 GTI 8v exhaust system including the manifold and downpipe, makes the engine rev better.  If you don't want to replace the stock manifold, you can fit an 1.8 Driver downpipe which fits the 1.6 manifold and has a bigger bore on the other end allowing you to fit the GTI system from the front silencer back.
Then get an 8v GTI cam which should give you a nice boost, then finish it off with a webber carb re-jetted on a rolling road to makle the most out of all the mods :)
Offline maximous
« Reply #2 on: 31 May 2005, 13:08 »
if i were you i would go for cams, full gti exhaust (polish the mainfold yourself), and one of those K&N filters. Then after that webber carb + advance the ignition and have it rolling roaded.
 I had a 1.6 driver that pushed out 106bhp from just using kent fastroad cams, advancing the ignition, using one of those K&N filter things and a backbox.
Offline Neaty
« Reply #3 on: 15 August 2005, 15:39 »
i have a set of twin webers 40's for sale if you're interested....£150 or so!
Offline jayc
« Reply #4 on: 04 May 2009, 00:39 »
is it really this simple? as i have access to an 8v gti exhaust system for next to nothing, i have a webber carb and i can also get the 8v gti cam? do you keep the cam in the oem position?
« Reply #5 on: 04 May 2009, 08:42 »
yes and yes :)
