Author Topic: Few PD150 Problems.  (Read 3822 times)
Offline Dean_W
Few PD150 Problems.
« on: 18 February 2012, 16:48 »
Any help with the following appreciated.....
Coolant guage fluctuates sometimes.
Takes ages to come up to temp.
I'm thinking thermostat and coolant temp sensor.  Opinions?
2002 GT TDI, Hybrid, Diff etc. 221BHP 355LB/FT
Offline Rhyso
Re: Few PD150 Problems.
« Reply #1 on: 18 February 2012, 18:11 »
Thermostat but you can change both as a precaution; get some fresh coolant in there too :afro:
Offline Dean_W
« Reply #2 on: 18 February 2012, 18:27 »
Cheers for that.  I noticed that the temp sensor ain't too bad to change, but upon looking at the location of the stat at looks a right pain.
Is it possible to change with the alternator fitted?  If so, anyone got any recommendations of best way to go about it?
Offline tdi_blu
  • Golf Gti & T4 2.5 tdi
« Reply #3 on: 18 February 2012, 20:06 »
I had to change both on mine when I bought the car you dont need to take the alternator off I didnt anyway just had to use a long extendable socket to get in there if the nuts crack first time its not to bad to do and im a novice with cars  :wink:
Golf Gti
Offline sprout99
« Reply #4 on: 20 February 2012, 08:09 »
try the green temp sender - my old A3 did this. Temp guage was slow to rise then just random.
Trust me - stat will be ok.
http://www.vwspares.co.uk/g4switches.php
25th Anniversary TDi - PD
Oak green mk2
V50 D5 Sportwagon
Offline Dean_W
« Reply #5 on: 20 February 2012, 13:09 »
Cheers sprout, where is that located?
Offline sprout99
« Reply #6 on: 20 February 2012, 20:03 »
Its on back of the engine. right corner of block if looking at engine bay, just above shift cables.
You can see it if you look down directly from intake pipe
Look for horse shoe clip. Buy new clip and o ring just in csse they get dropped or damaged
« Last Edit: 20 February 2012, 20:06 by sprout99 »
Oak green mk2
V50 D5 Sportwagon
Offline Dean_W
« Reply #7 on: 20 February 2012, 20:35 »
Cheers, much appreciated.
