Author Topic: Carbon canister delete how to  (Read 67304 times)
Offline Scott-R
  • GoT BoosT!
Re: Carbon canister delete how to
« Reply #20 on: 22 February 2013, 22:00 »
If I buy a new canister will the ticking go away?
Golf GTI ... What else would you have?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #21 on: 24 February 2013, 13:20 »
nope the ticking is the N80 valve in the canister
Offline dom
  • Back in a Mk4
« Reply #22 on: 16 June 2013, 15:28 »
Just to add to this, I've just done this and it is slightly different on an AUM.
The pipe that goes from the throttle body and then T's into the carbon canister doesn't run to the bulkhead and along it to the TIP.
Instead it runs to a hardline that runs underneath the FPR, at the other end there is another small hose that joins it to another hardline which runs behind the coolant temp sensor. The other end of that hardline is joined to the TIP via a hose.
jamie16v
« Reply #23 on: 16 June 2013, 17:22 »
Done it! I kept the solenoid attached and tucked it under the expansion bottle. As this still keeps an electrical loop/resistance, will it keep fault codes at bay? Or does it somehow measure the flow or something?
To answer your question, what you did is fine. the resistor is only to make the clicking stop. this is what i have done for now, but i do have a resistor in the glovebox ready for when i can be arsed to do it!
Offline viperjsy
« Reply #24 on: 04 August 2014, 21:12 »
hi how did you wire the resistor
Offline Dalo Harkin
« Reply #25 on: 21 August 2014, 11:01 »
when you take the plug off the carbon canister, chop the connector off there are 2 wires, connect one to either end of the resistor with a choc block or solder them  :wink:
Offline viperjsy
« Reply #26 on: 23 August 2014, 21:21 »
thank you
Offline shaunf1.8t
« Reply #27 on: 01 November 2014, 22:04 »
hi just wondering would deleting this give any exhaust emissions problems that would fail an MOT? hope that makes sense!
