Author Topic: Carbon canister delete how to  (Read 67305 times)
Offline bricey
  • One of a few with a PROPER engine
Re: Carbon canister delete how to
« Reply #10 on: 03 March 2012, 16:34 »
resistor orderd mate :cool:
DOLPHIN TRAINER
Offline bricey
« Reply #11 on: 21 March 2012, 19:20 »
wes do you know how to code the evap system out altogether?
keeps throwing codes doing my head in
DOLPHIN TRAINER
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #12 on: 21 March 2012, 22:30 »
it shouldn't throw anything with that resistor in there AFAIK...
Might be worth a call to Nick to see if it's possible to do it...
Offline GTIcheeseman
« Reply #13 on: 28 May 2012, 19:38 »
so do you ust connect the resistor up to the pin that has the positive feed? bit confused on that bit
« Reply #14 on: 29 May 2012, 11:00 »
Is it safe to just stick the petrol breather pipe outside?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #15 on: 02 June 2012, 14:00 »
mine has just been poked out of the wing and is resting on the arch liner so it doesn't come in contact with the tyre. I also stuck a cheap breather filter on the end
Offline paultownsend
« Reply #16 on: 15 July 2012, 23:59 »
Can you just go over exactly how to connect the resistor to the plug.
I want to keep the original plug, incase things go wrong!
Offline Dalo Harkin
« Reply #17 on: 16 July 2012, 12:41 »
There is nothing to go wrong, if you cut the connector off using wire cutters, leave yourself an inch or so per wire and if at some point you want to reconnect the carbon canister, solder the wires and heat wrap - job done  :wink:
« Reply #18 on: 16 July 2012, 20:15 »
 Done it! I kept the solenoid attached and tucked it under the expansion bottle. As this still keeps an electrical loop/resistance, will it keep fault codes at bay? Or does it somehow measure the flow or something?
Offline jamie1989
« Reply #19 on: 17 July 2012, 10:06 »
Did you remove the metal piece in the connector? I had to use a alan key to remove it as mine kept ticking away lmao
I did the same but removed the plastic trim under the windcreen and zip tied it away tidy out of the way from the wipers and put the trim back on  :grin:
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
