Author Topic: boost gauge  (Read 2593 times)
Offline kennedyuk2001
boost gauge
« on: 17 February 2012, 10:06 »
I have my boost gauge I removed from the impreza, I would like to fit it to the golf, just curious what vacuum pipe I should hook into, or do I need to tap into the inlet manifold like I seen on a guide for fitting? Also were is easiest to hook into for power.
Regards
Offline Rhyso
Re: boost gauge
« Reply #1 on: 17 February 2012, 10:27 »
On a TDI you tap into the EGR to intercooler pipe
For power use the blue / grey wire behind the light switch as that will also allow you to dim the gauge with the dashboard lights
Re: boost gauge
« Reply #2 on: 18 February 2012, 14:55 »
Cant seem to find a site or on eBay for a suitable tap. any good site or eBay link you know of?
Offline Rhyso
Re: boost gauge
« Reply #3 on: 18 February 2012, 18:10 »
Afraid not as mine came off the port on my EGR delete pipe
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: boost gauge
« Reply #4 on: 18 February 2012, 18:50 »
I just fitted mine today, a small tap of the EGR delete I had. I have seen people removing the inlet manifold, drilling and tapping a hole then screwing in a suitable connector. Be careful as I think the inlet mani is quite soft!
