Author Topic: abf head water temp sensor  (Read 1601 times)
Offline leeroy20vt
  • h reg mk2 gti
« on: 16 February 2012, 21:15 »
is there any way to put another temp sensor in on a abf head or do they have to go into one of the water pipes
reason i ask is i have a spare water temp gauge i want to put in just to be on safe side
cheers
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: abf head water temp sensor
« Reply #1 on: 16 February 2012, 21:21 »
Hmmm..  I had this problem,  i had a brass threaded sender,  but the golf is a plastic type thing, I eventually added in a small section of metal pipe where the top rad pipe meets the head and threaded it into that.  I cut the silicone hose and added it in there.  Might be somewhere better on the valver engine, but couldnt find any other way in the 8v.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline leeroy20vt
  • h reg mk2 gti
« Reply #2 on: 18 February 2012, 15:41 »
cheers m8 i think thats what im goin to have to do i have found a spare hole on the head but its just a hole with thread init so its not going to be in the water to tell the temp
any one know the diameter of the top hose on a abf ?
