Author Topic: ABS Issues  (Read 4168 times)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: ABS Issues
« Reply #10 on: 16 February 2012, 16:40 »
it is odd, was it dropped or hit at all? they are very sensitive.   Could just be a fautly one, you never know.   Does it say its the sensor open/short to ground?  I know vag-com shows "mechanical failure" which is when the pulse ring is damaged/bent sort of thing. What diagnostics are you using, as it could be finding a general fault, but not telling you exactly what the fault is?  Just a thought.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: ABS Issues
« Reply #11 on: 16 February 2012, 17:24 »
Id say your ECU for the ABS pump is fooked
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline boneybradley
  • Back in a Mk3...
Re: ABS Issues
« Reply #12 on: 16 February 2012, 19:00 »
you can test the resistance in the sensors fairly easy, that will count them off at least. vag-com etc is good but not perfect!
(there's a thread in the mk3 maintained section showing how to)
Offline Jasikasisback
Re: ABS Issues
« Reply #13 on: 18 February 2012, 23:20 »
Solution one: drive over speed bumps and brake quickly once over. This somehow helps.
Two-drive in the rain, and brake suddenly.
Three-blow air on the sensors
Four-just pray and tell the car you will scrapnor sell to someone.
Five-repalce abs unit and sensors
Six-disable abs systen.
Offline Dogbot
Re: ABS Issues
« Reply #14 on: 19 February 2012, 20:05 »
Thank fook someone else said it.... i was thinking it....
I hate ABS I Cant do it myself brakes, as such they are disabled...... pull the fuse man, she'll sail the mot....
An safety wise, if you brake right you can still pull up just as fast as a car with abs working....
Offline dom
  • Back in a Mk4
Re: ABS Issues
« Reply #15 on: 19 February 2012, 22:12 »
Pull the fuse and it will FAIL the mot, not sail :rolleyes:
Offline Dogbot
Re: ABS Issues
« Reply #16 on: 20 February 2012, 17:21 »
[/quote]
Mines been through two mot's & never once has it even ever been mentioned....
both in different testing stations, & my brother's A3 is the same, for the last three years...
I just make sure the light doesnt come on at all,
(I'd just like to add that I'm not one of these that would sell it on without informing the potential buyer)
I know there where some testing ammendments that came into effect in febuary regarding saftey feature lights, but mine went through after those so assumed not much had changed i.e if it didnt light up it werent tested
« Last Edit: 20 February 2012, 17:27 by Dogbot »
Offline trog_nfs
Re: ABS Issues
« Reply #17 on: 20 February 2012, 17:36 »
Not lighting up at all will fail now mate
Offline dom
  • Back in a Mk4
Re: ABS Issues
« Reply #18 on: 20 February 2012, 18:35 »
This, MOT regulations have changed. As of 01/01/12 it will appear as an advisory if it does not light up, as of 01/04/12 it will be reason to fail.
Offline todd
Re: ABS Issues
« Reply #19 on: 20 February 2012, 19:23 »
That is correct always has been plus with the abs disabled it will make the rear end very tail happy when braking as the load sense valve as such is built into the pump and not on the rear beam as non abs cars are replace the sensors and you should be ok if not pumps are easy to get hold of plenty being broken on here :)
