Author Topic: Golf 1.9 tdi, should i be worried??  (Read 2094 times)
Offline new to vw
« on: 15 February 2012, 16:42 »
Just topped up the oil and found salad cream under the filler cap....I have been topping up the coolant as well..
Could the salad cream be a result of only doing short journeys in the cold weather we have just had and the oil is not getting upto temp or is a head gasket job
 :sad: :sad:
5 door 1.8t AUM
Offline dubber36
Re: Golf 1.9 tdi, should i be worried??
« Reply #1 on: 15 February 2012, 17:20 »
It sounds very much like a head gasket  :sad:
Offline robster52
« Reply #2 on: 15 February 2012, 17:57 »
Need to worry unless the car is really old and you think the gasket is passing.
doing short journeys causes this mayonaise because as u say u get condensation on the inside of the cylinders. wipe underneath the cap and take the car for a few long runs and it'll clear. Had this on my TT and it soon cleared up
« Reply #3 on: 15 February 2012, 23:50 »
Clean it off and give the car a long run.
Offline new to vw
« Reply #4 on: 16 February 2012, 09:06 »
Just a quick update, the coolant system isnt under presure whe the engine is cold..
5 door 1.8t AUM
Offline Mr Savage
« Reply #5 on: 16 February 2012, 09:51 »
Also had the same problem on another car in the past. In my case it was due to short journeys in the cold weather and as others have suggested, wipe it down (make sure no lint or the like gets inside the cap) and give it a good few long runs then check your oil. For me it didn't clear instantly on the first run but eventually did after a week or so of extra driving. If it doesn't clear after that then you should start to worry as chances are it's the head gasket.
Current - MK7 Golf GTI - Tornado Red, 5 Door, DSG, Performance Pack, Dynamic Chasis Control, Panoramic Sunroof, Discover Navigation, Dynaudio.
On Order - MK7 Golf R - Pearlescent Black, 3 Door, DSG, Vienna Leather, Discover Nav Pro, Rear View Camera, High Beam Assist, Keyless Entry, Dynaudio (Tech Pack)
All gone.
Now;
MK7 Golf R - Lapiz Blue, 5 Door, DSG, Carbon Nappa, Discover Nav Pro.
