Author Topic: AGU vs ARZ vs AUM - which would you choose?  (Read 10930 times)
Offline the_hamster
« on: 15 February 2012, 15:20 »
Time to pick the brains of all of you who've been there and done it.
My goal is to turn a 3 door turbo into a fast road/track car BUT it will also be styled, not a stripped out racer. Ideally I will be looking to get the power up, especially torque so which of these engines is likely to be the best starting point? And before anyone says it, I cant afford to go BAM yet, I'm looking at taking a standard car and modding it over time rather than throwing big bucks at it in 1 go. Does the earlier AGU with larger ports have much more benefit to it than the AUM or is there really nothing in it?
Now this might sound daft, but I might also want to fit cruise control and from what i've read, you cant do that on an AGU (cable throttle), whereas its a £100 retro fit on an AUM. 300 miles of autobahns to the Nurburgring leaves me with a dead leg most of the time so cruise would come in handy.
If anyone wants to tell me their experiences, what they did and what they would have done different then i'm all ears. PLEASE PLEASE remember tho, I'm never going to be able to afford an expensive conversion, it has to be a steady progression for me as I only have £50-300 a week on average to spend and i'm crap at saving!!
Offline Granta Gti
Re: AGU vs ARZ vs AUM - which would you choose?
« Reply #1 on: 15 February 2012, 17:25 »
I have an ARZ and that has drive by wire so cruise control capable but I have had it mapped and I think it is down on torque compared to the others because it has the small turbo and small ports ( correct me if I'm wrong!). The ARZs are quite rare I believe?!
Offline symsymma
  • AGU POWER,drive it like u stole it!!!
« Reply #2 on: 15 February 2012, 17:41 »
For modding engine id get AGU because the internals are stronger and the coil packs better and other parts more reliable imo.but like you say you cant retrofit cruise control.buy an AGU already with cruise control and put an AUM turbo (k03S) on it.
1.8T AGU 203bhp & 233lb/ft Rtech stage 1 custom remap,18"dezentz rims,lowered 40mm shocks n springs,whiteline 24mm adj rear arb,lcr axle bushes,polybushed arb,modified front bumper & valences,depo projector headlights,delocked,wrapped interior&bora gear knob,forge boost & coolant hoses,forge tip,forge 007p,samco vac hoses,simota aeroform cai,saiko michi catch can,deleted pcv system,r32 dogbone,miltek lg bore down pipe & sports cat/non res anni style system.
Offline gm8
« Reply #3 on: 15 February 2012, 17:53 »
you can get an agu with factory cruise control fitted tho (i have one and some others here do too)
Offline the_hamster
« Reply #4 on: 15 February 2012, 17:59 »
Ok, ignoring the cruise control and concentrating purely on power and potential would a 1998 AGU car be better than a 51 plate AUM? This is basically what i'm wondering  :smiley:
Offline shaft69
« Reply #5 on: 15 February 2012, 18:31 »
Aum but thats just because ive got one but if looking power agu with rods, its more basic engine being 1st 20vt. Run one of those with gt30 and meth inj awesome. Depends on how much power your looking if upto 300bhp any 20vt, if towards 400bhp and up agu with rods, pistons and big ass turbo.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline the_hamster
« Reply #6 on: 15 February 2012, 18:49 »
400, in a fwd?
300 will be enough for me, dont want the hassle of meth, just a decent turbo and engine that wont blow apart.
What turbos will fit the standard manifold? Any recommendations apart from the 03s and 04?
Offline stevelfc
« Reply #7 on: 15 February 2012, 20:33 »
AGU engine is best  :grin:
Offline Toby
  • Car - less
« Reply #8 on: 15 February 2012, 20:54 »
ko4 agu yeh boiiiiiiiii!
agu, what came first, came best.  :cool:
Currently down under
Offline shaft69
« Reply #9 on: 15 February 2012, 20:59 »
Any for 300bhp this is greggory's just shy of 400bhp
184 Wallgate, Wigan
WN3 4AL
07966492823.
