Author Topic: exhaust manifold gasket change...  (Read 1038 times)
Offline MK3GTISI
« on: 15 February 2012, 14:55 »
Just bought myself a nice golf gti ,few little issues to fix,one  of them being echaust manifold how hard is this to do?
Offline CJA321
Re: exhaust manifold gasket change...
« Reply #1 on: 15 February 2012, 15:28 »
A total and utter ball ache.............
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #2 on: 15 February 2012, 16:23 »
Basically. Ha.
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #3 on: 15 February 2012, 16:54 »
Its a total b*tch if you dont snap any studs,  its a complete nightmare if you do.... enjoy   :grin:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline MK3GTISI
« Reply #4 on: 15 February 2012, 17:56 »
Thanks lol
Does anything need to be removed before doing the job or can you get to the bolts from above the engine?
Offline CJA321
« Reply #5 on: 15 February 2012, 17:58 »
Underneath  :smiley: :grin:
Offline sharki786
  • GOT BOOST??
« Reply #6 on: 15 February 2012, 19:42 »
its a c*nt to do trust US!! you got to remove the gearbox mount and front mount and the rear engine mount will need to be loosened use an engine crane or a jack on the sump, pull the engine forward as much as possible and then bend over and get F*CKED!!! lol it will take over 3 hours to get the nuts off, take the intake manifold off.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Rmachines
« Reply #7 on: 15 February 2012, 19:57 »
What i do is disconnect the engine mounts, and hold the engine on a jack with the front up on stands, you can tilt the engine right forwards as far as it will go (without snapping stuff) you need access on top and underneath, take the heat shield off,  then the manifold,  its actually much easier to take the intake manifold off while your there, just incase you need to remove studs or anything.
« Reply #8 on: 15 February 2012, 23:42 »
A lot easier from underneath with the car on a ramp.
