Author Topic: Noisy Cam Shaft  (Read 1490 times)
Offline AlexMozza
Noisy Cam Shaft
« on: 15 February 2012, 13:45 »
I know its not a golf, but I cant seem to find any information on it, and It should be a pretty generic answer :D
When I start my satria GTi the cams seem rather loud, but after a minute or two they go quiet.
I have just done a full service and engine flush as I have been told that some cam shafts have oil channels that can get blocked over time.
The noise does not seem to be affecting anything, just curious to what is causing it.
Thanks
2001 Satria GTi
Mini 25 Special Edition 1984 998 :D
Formula 3 Mechanic
Offline Hoggy
  • Mk4 GT TDI 150.
Re: Noisy Cam Shaft
« Reply #1 on: 15 February 2012, 19:34 »
Could  be worn tappets and/or followers in the head mate?
Hoggy.
Offline Khare
  • The bear that khares
Re: Noisy Cam Shaft
« Reply #2 on: 15 February 2012, 20:16 »
It may be that you've got an oil filter that doesn't have a non return valve, so over a period of time the oil drains completely to the sump, and although when you start the car it will get oil at the top end straight away, it may take a while for the oil to work into the tappets. As Hoggy said it may be worn tappets as well though.
Offline AlexMozza
Re: Noisy Cam Shaft
« Reply #3 on: 15 February 2012, 20:25 »
That's what I thought Khare :)
Well its not bothering me and I'm planning to rebuild the engine soon as I'm putting a evo 3 tubo on it :)
2001 Satria GTi
Formula 3 Mechanic
