Author Topic: passats done a few miles.  (Read 2170 times)
Offline danny_p
« on: 14 February 2012, 23:07 »
rolled 190k doing course car duties at weekend
still works  :shocked:
still havent changed the clutch ether.
question is  is it worth putting a clutch in a 1.8T with those miles
« Last Edit: 14 February 2012, 23:13 by danny_p »
all the VW's have gone bar 1.
Offline topher
  • Administrator
  • fully functioning
Re: passats done a few miles.
« Reply #1 on: 14 February 2012, 23:19 »
either its not driven far when the pic was taken or it needs a thermostat, brake warning light is on.. is that STOP message for oil pressure? simple fixes so if its not rattly and it boosts okay whack a clutch in it i've seen them live on to 250k+ miles
Offline danny_p
« Reply #2 on: 15 February 2012, 00:08 »
Stop light and brake warning light come on together.   it dose that sometimes  presume the ABS ecu/pump is dyeing as you can't read any codes off it when it's haveing a fit.  thats an evening job some point as i've got a spare pump/ecu module
thermostst is ok, hadnt gone very far when took photo    about a 1.5 mile of forest track
no tappet rattel fixed that,  wastegate rattels but it's allways done that,  ecu occasionly flags p1556  aka negative charge pressure deviation   keep meaning to have a proper look at sorting that when get 5 mins.
been wondering if it'll make  225622  miles.
Offline justalex81
« Reply #3 on: 15 February 2012, 19:39 »
my mate has a t reg mk4 turbo and it's done over 235k. he doesn't look after it either!
Offline barrym381
« Reply #4 on: 15 February 2012, 19:54 »
not long sold my 4mo with 185k on it  :smiley:
Offline danny_p
« Reply #5 on: 15 February 2012, 20:14 »
the 20v A4 the passat replaced got to 160K.   then cylinder 1 ate itself
looks like there may be a few more miles left in the bus then
Offline wessexgti
« Reply #6 on: 15 February 2012, 22:07 »
my mk4 golf gti 20v turbo(agu) has 195,ooo and still drives sweet.im the 3rd owner,both the previous owners looked after it well so im doing like wise. (just waiting for something major to go wrong n fcuk me right up!)
Offline JC
  • Back in the North.
« Reply #7 on: 15 February 2012, 22:09 »
 :shocked:  :lipsrsealed:  :rolleyes: that is all
Offline gti gaz
« Reply #8 on: 16 February 2012, 18:42 »
i am looking at a 1.8t passat at the weekend with 141k on it seeing yours with 190k sets my mind at rest   :smiley: :smiley:
 Any one in cornwall lets sort more meets!!!!
Offline boneybradley
  • Back in a Mk3...
« Reply #9 on: 16 February 2012, 19:13 »
fit a std non dual mass clutch set up if you don't think £500+ is worth it! (mines non dual mass and apart from a little more vibration, it's 99% ok!)
