Author Topic: 16v p/s pump,What else fits????  (Read 3244 times)
Offline 01664gti
  • mk3 hatch mk3 wagon and mk2 16v
« on: 14 February 2012, 22:04 »
Hi all
I need a mk2 16v p/s pump but cant find one but have been offered a mk3 16v one if it will fit.
Anyone know if it will or any other i could look out for??
cheers in advance
Re: 16v p/s pump,What else fits????
« Reply #1 on: 14 February 2012, 23:44 »
I am sure the pulley is different on the mk3 one but you may be able to swap that over, not sure if 8v is the same.
Offline Ben Lessani
« Reply #2 on: 15 February 2012, 08:57 »
8v is the same, Corrado is also the same. But mk3 uses ribbed belts not v belt, so you've got to change a fair bit too use it
Offline 01664gti
« Reply #3 on: 15 February 2012, 10:23 »
ok cheers ill start looking then
glove
« Reply #4 on: 15 February 2012, 18:55 »
« Last Edit: 22 April 2012, 00:45 by glove »
Offline clipperjay
« Reply #5 on: 15 February 2012, 23:25 »
Shaft on a 16V is shorter than a 8V to be clear there is defo a difference in shaft lengths!
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #6 on: 15 February 2012, 23:32 »
.. to be clear there is defo a difference in shaft lengths!
Bum Start?
Offline Ben Lessani
« Reply #7 on: 16 February 2012, 01:24 »
Nothing that can't be spaced out :) I've got a 16v pump on my 8v
Offline clipperjay
« Reply #8 on: 16 February 2012, 22:53 »
Bum Start?
Jeez man didn't you get breast feed enough as a pup Jon  :evil: :drool:
Yeah spacers can be used it's only about 10mm-15mm difference!
