Author Topic: Removing struts  (Read 1295 times)
Offline mkviken
Removing struts
« on: 14 February 2012, 10:23 »
If anyone has swapped they own front suspension could you tell me if you had to pull the hub off or not to get the strut out?
I've seen a how to guide which said you have to remove the bottom ball joint and pull the hub out but I've also seen one which says you can do it just by removing the ball joint and pulling the control arm down out of the way.
can anyone confirm if the hub needs pulling or not
cheers
Golf GTI 7.5 230 white silver
