Author Topic: Need gearbox parts suppliers for my 020 gearbox  (Read 1336 times)
Offline VEEDUBMAD123
« on: 13 February 2012, 22:19 »
Hi there i'm having gearbox problems with my 020 box its noisy in reverse and 1st an2nd syncro are on there way out to i'm going to strip the box down and do a rebuild i'm a vehicle technician so know what to do i've stripped loads of box's in my time,i'm after gearbox parts suppliers i've found fast track bearings so got some parts but need suppliers for the syncros and other parts so can anyone help me with any companies you know any info will be a help......thanks for your time    Rik
P.S   i drive an R reg 98  mk3 golf gti 2.0L 8v........
Offline ryanpretty
Re: Need gearbox parts suppliers for my 020 gearbox
« Reply #1 on: 14 February 2012, 09:11 »
dont know if this helps or were you live but a have a 2nd hand gearbox out of a mk2 golf gti (should be same box) that you can have for cheap - 30.00 plus you arrange courier
cheers ryan
Offline Dan_GTi8v
« Reply #2 on: 15 February 2012, 00:40 »
stevens vw dismantlers are good google and give them a ring. there in essex but can post
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #3 on: 15 February 2012, 17:13 »
When doing an overhall, i usually get the parts from the dealer, I have not tried these other companies to be honnest but i hear good things..   Im also a tech and do a fair few rebuilds, i only replace what is needed, i havnt found any full kits.   1/2 syncro hub comes with both syncro rings,   same with 3/4 i think, i forget the order now, but i usually order the hub complete with the main and counter shaft bearings with the roller bearings for the gears, replace the reverse idler too, you will have a chipped tooth, the shafts usually stand up to the abuse the broken tooth gives them.  Oh and to the DIFF MOD!!   fit the bolts rarther than those awfull rivets.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
« Reply #4 on: 19 February 2012, 11:40 »
Hi there thanks for your replies what price are the genuine hubs not priced them up yet mate..................thanks Rik
P.S   gonna do the repair myself so don't need secondhand box but thanks anyway......
Offline Rmachines
« Reply #5 on: 19 February 2012, 12:12 »
From what i remember (this was a while ago) the 1/2 syncro hub was £85 ish, which is a fair price for a dealer, this was about 3 years ago though.  The other hubs would be a similar price.
« Reply #6 on: 24 February 2012, 20:13 »
Hi ryan can you tell me the gearbox code please mate and what mk2 golf did it come out of too mate....thanks   Rik
