Author Topic: Drilled air box question :-s  (Read 1396 times)
Offline Povey
« on: 13 February 2012, 13:03 »
I know this has been covered all the time but I can't seam to find any decent pics r info,
Basically I want a bit more noise and iv been told drilling and smoothing is the way forward?
My car is a 1.8 gl so nothing special there,
In te air box there look to be some sort of valve in the bottom leading the manifoldand a tube thing only a small thin one whats that for i want to l ow cn i rip that valve put with out measing my car up?There is also some tubes going into the air box other than the ones that draw the air in, what do these do?
Any info would be great and pics too if you have them?
Offline trog_nfs
Re: Drilled air box question :-s
« Reply #1 on: 13 February 2012, 13:12 »
The little tube goes to the mainfold; its a vacuum hose.
The little valve moves about in cold weather on start up to direct warm air into the intake to stop it freezing up. There should be a hose going to the heat shield so that hot exhaust warmed air can be directed in.
If you do remove it, make sure you plug the vacuum hose. I've heard of people using bolts and hose clamps before.
Offline Povey
« Reply #2 on: 13 February 2012, 13:30 »
Wicked thanks bud!
 So if I blank the small hose and take out the flap my car will still run alright? But might be a bit tricky to start up when bloody cold?
Offline AudiA8Quattro
« Reply #3 on: 13 February 2012, 14:38 »
The valve is there to stop fuel freezing, as it is injected so high up, i assume this is a single point injection.
When the inlet air temp goes below a certain value the valve operates a flap which directs hot air off the exhaust manifold back into the inlet.
This is not just for starting, the system works all the time..
Offline Povey
« Reply #4 on: 14 February 2012, 09:41 »
Yeah it's a single point injection, basically I know my cars neve guna be quick and the 1.8 gl is pretty much useless to tune big if I can make it a little louder and sound a bit more sporty that will be nice :-)
Can any one give me some pointers on what to do to my airbox with out screwing up the drivability that will be cool.
Offline Li-D
« Reply #5 on: 14 February 2012, 11:46 »
Best bet would be to post a pic up of engine with airbox, would be easier to advise
Mk3 Golf TDI - GTD replica in progress....
OEM CHIPPED....
NO POKE WITHOUT SMOKE!
« Reply #6 on: 14 February 2012, 13:14 »
Unfortunately there is very little you can do with the airbox, maybe fit a k&n, that will give you a bit of noise.
I wouldn't make any holes or remove any of the hot air feed.
