Author Topic: What is a boost gauge?  (Read 1651 times)
Offline DMcK
  • Red MK4 Golf 1.8T. Unmolested...Soon to change!
« on: 12 February 2012, 16:59 »
I've had a search on here but can't find anything explaining what a boost gauge is. Could someone please explain what they are, used for and if necessary please? Cheers
Offline AlexMozza
Re: What is a boost gauge?
« Reply #1 on: 12 February 2012, 17:20 »
The measure the amount of boost pressure on a turbo or supercharged engine, and display it in either BAR or Psi (Or both) on a dial gauge.
2001 Satria GTi
Mini 25 Special Edition 1984 998 :D
Formula 3 Mechanic
Offline DMcK
« Reply #2 on: 12 February 2012, 17:24 »
Is it good to have on a car or ok without? I have a Mk4 1.8T.
« Reply #3 on: 12 February 2012, 23:56 »
Very handy to have one, lets you keep an eye on the boost levels and you can soon spot if you have a problem
Offline AlexMozza
« Reply #4 on: 13 February 2012, 09:40 »
Very useful if your running high boost levels.
If not as Wayne said you can see if your boost levels are low, for example if you have any cracks in hoses.
If you don't have one there is no problem :)
2001 Satria GTi
Formula 3 Mechanic
Offline DMcK
« Reply #5 on: 13 February 2012, 11:13 »
Cheers people. Might invest in one then. Would rather know if I have a problem.
