Author Topic: Ebay powerchip verdict  (Read 14023 times)
Offline Khare
  • The bear that khares
« on: 11 February 2012, 15:53 »
Before power/torque
Before power/AFR
After power/torque (sorry for bad pics, scanner isn't working)
After power/AFR
9hp increase! The chip is the only modification I've done since the previous dyno run. Results are quite clear. Graph is smoother and torque and power is more linear, with torque getting a very nice boost after 4500rpm. Those who know (Glen, I'm looking at you especially), what can you tell me from the AFR of the new output? Is it running lean/rich at any point in the range?
Offline twotwofour
Re: Ebay powerchip verdict
« Reply #1 on: 11 February 2012, 16:01 »
Looks like that chip is some kind of amplifier. It's just made the fuel richer in a few places. Optimum a/f is 13 and it's not far off. The lower than 13 at the start or the graph would be for emissions.
Mk2 small bumper 16v 3dr golf gti
Mk3 5dr 8v golf gti x2
Need a mk1 gti, mk1 caddy, mk3 vr6
Offline Screech16v
  • MK3 20vt AGU
« Reply #2 on: 11 February 2012, 16:18 »
Great result, i reckon youll get better mpg also,i know i did  :cool:
Offline murraymint
josh
Offline Khare
« Reply #4 on: 11 February 2012, 16:20 »
Yeah MPG has been better ever since fitting the chip. Only while cruising though.
Is that this chip?
http://www.ebay.co.uk/itm/320823949535?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649#ht_998wt_689
That's the one.
Offline murraymint
« Reply #5 on: 11 February 2012, 16:27 »
Someone's sales are gunna go up because of this.
Sticky??? Too save future threads asking the same things
(because this never happens in the mk3 section lol)
josh
Offline Khare
« Reply #6 on: 11 February 2012, 16:30 »
Ditto. I should be given commission!  :grin:
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #7 on: 11 February 2012, 16:44 »
Top banana! I should expect mine to be producing very similar results to yours then mate.  :smiley:
Offline Khare
« Reply #8 on: 11 February 2012, 16:46 »
Yup, as all chips are written with the same map. I wonder why RJ only got 6hp though?
Oh yeah, and this also proves drilled/cut airboxes do NOT make you lose power!
« Reply #9 on: 11 February 2012, 16:50 »
In regards of RJ's results I'd assume that would be down to different variables on the day, temperature, fuel used, engine health, tyre pressures, dyno set up etc etc
