Author Topic: Gearbox question ??  (Read 2358 times)
Offline Deano2711
  • 1992 VR6
Re: Gearbox question ??
« Reply #10 on: 13 February 2012, 19:46 »
So how much did it cost for a mk2 gti clutch?
I took it in on Wednesday with a 2ltr GTI clutch which he fitted then removed, he then ordered the clutch I needed and fitted this. Then he replaced the inner boot on the drive shaft which had split and I got the car back this afternoon alongwith a bill for 250 smackers.
Offline tweed
« Reply #11 on: 13 February 2012, 19:57 »
I'm in the wrong game  :laugh:
Offline Adezmk3
« Reply #12 on: 13 February 2012, 20:23 »
Anyone know if a 1.6 gearbox will fit a 2.0 8v AGG?
VW BUSH
« Reply #13 on: 13 February 2012, 22:01 »
Fitted a KR box from a Mk2 on my last 8v, bolts up fine just uses a different size clutch and plate.
Gives you a bit more take off :smiley: and a slightly lower top end iirc.
Offline dub-gti
« Reply #14 on: 23 February 2012, 12:58 »
so a mk2 kr box will fit a mk3 abf ? mines a 2.0 16v
Offline Dan_GTi8v
« Reply #15 on: 23 February 2012, 18:03 »
abf standard is an 02a box which is hydraulic clutch and cable shifter. If going from and 02a to an 020 you will need to convert to a rod shifter and cable clutch, which is kind of going backwards
VW BUSH
« Reply #16 on: 23 February 2012, 22:05 »
What he said, I had one lying around and its a simple bolt up job for an 8v :smiley:
