Author Topic: I just bought this!  (Read 2572 times)
Offline Len
Re: I just bought this!
« Reply #10 on: 10 February 2012, 13:34 »
Nice!
www.sas.org.uk
www.the-ace.org.uk
Offline haf1zur
« Reply #11 on: 10 February 2012, 13:38 »
My garage is 17 by 8, i've given up using the big 3 ton jack.
I've got a slightly smaller 2 ton jack now  :rolleyes: :laugh:
do you have much room either side?
theres a garage going near me, 8x16ft, thinking i may take it if theres enough space to jack it up either side etc
Offline AudiA8Quattro
« Reply #12 on: 10 February 2012, 14:13 »
Depends what car you have.
For a golf it is good enough, for an Audi or other saloon/estate it can be a bit tight.
Offline clipperjay
« Reply #13 on: 10 February 2012, 15:23 »
That looks identical to my Blue point one, twin ram, fast lift and only 72mm entry height.
You wont go wrong with that fella.
This one is 89mm or 8.9cm height entry its not as low as my Proline ones, but more than enough clearance on a Dodge
Even 6cm I struggle to get under the MK2 as its an inch off the ground (not my doing)
I paid £80 odd for it not bad for the money considering resealing my other two might be about £30 each!
Offline salsheikh
« Reply #14 on: 10 February 2012, 18:04 »
my old mans got one and they are really good. only down side is the rubber pads soft so wears away pretty quickly. mind you, his is in daily use being a mechanic.
Offline jettagolf
  • Mk2 Golf GTI
« Reply #15 on: 10 February 2012, 21:47 »
I have one of these, they are fantastic I use it for my t4 lifts it easy, it's heavy though :laugh:
Offline Dolly
« Reply #16 on: 10 February 2012, 21:56 »
how much that set you back, i could do with a heavy duty jack
Offline clipperjay
« Reply #17 on: 10 February 2012, 22:06 »
£80 mate!
