Author Topic: raplacing the ignition loom  (Read 939 times)
Offline dubpirate
« on: 09 February 2012, 20:02 »
has anyone ever done this
iv bought a new one
so i can remove this sh!tty push button start
were do all the wires go
obv theres 3 plugs that go into the ignition barel and column
were is the other ends of these go
Offline Dan_GTi8v
Re: raplacing the ignition loom
« Reply #1 on: 10 February 2012, 14:11 »
have a look at this
http://www.a2resource.com/electrical/CE2.html
according to that it is positions H1 H2 and J in this diagram
full ignition loom though I thought had more than 3 plugs at the steering column, all the stalk controls should be up there somewhere too, unless you are only replacing what needs to be replaced, but in that case from memory there are only 2 plugs fusebox end hat needs to be changed
have a look at the link and work it out :P
« Reply #2 on: 10 February 2012, 23:50 »
Why not rip out the push start and tidy the wiring or is it a mess.
Offline dubpirate
« Reply #3 on: 11 February 2012, 13:31 »
ust bought a new ignition loom pal guna rip it out and put all back to standard
« Reply #4 on: 12 February 2012, 00:07 »
Good luck with sorting it :afro:
