Author Topic: mk4 tdi battery drain, ccm or new clocks required any vag coder in s.wales?  (Read 4308 times)
Offline huwgarms
hi as above
 i have a small electrical drain, we have re done the connections inside the boot near the rear tailgaite etc - car is v plate mk4 tdi, and has been with auto electrician for the last two days, hes narrowed it down to either the clocks or ccm unit, removing either prevents the drain?,
 the ccm, im guessing is connected to the clocks in some form at some point , im guessing new clocks first then maybe new ccm, may even change both, seen some on the bay for £25 ish each, just then need to find someone local to code them? any ideas in wales whos about? also indication of costs for each on a budget and at the min im running about with no fuse 14 fited and no alarm etc
ive got the code for the ccm unit and theres one on the bay havent got the code for the clocks though as the dash is back together now for use?
Offline Steve_PD
PM Rhyso he might be able to do it.
Offline blade4real2004
  • golf gti with a touch of .:R
u get stuck finding someone give me a shout
k04s | jabba cai | stage 2 (Rtech) | forge 007p | forge boost hose set |forge tip | THS fmic | gen r line kit | bbs ch | TT short shift | R32 vents | full stainless | decat | auto windows | mk5'd boot
need a scan or mod with vagcom & vagtacho PM ME (south wales area)
my build thread - http://uk-mkivs.net/forums/t/236415.aspx?PageIndex=1
Offline huwgarms
many thanks both blade4real are you in south wales ?im in the rhondda area but willing to travel to get things sorted, is there a way to find out which clocks are compatable if i have to change those? if i change the ccm how do i get the remote key to work?
thanks again
Offline huwgarms
still looking for vagcom in wales
